98 part throttle retard?
Occassionally it will get a retard spike when lifting off the throttle, although it seems I have that mostly gone. Is this real? I would really like to tune it out rather then just make it not appear if its real. Could it be drivetrain noise? I never audibly hear knock. Maybe its time for a knock box with earphones.
oh yea, one of my last tests was adding timing, I added 4-8 degrees in the middle and smoothed it alot, and there is no real difference, wot timing is at 13-14 degrees. As soon as it sees any power its basically at 25 and going down. Hi timing /low timing seem to make no difference.
To test these additional possibilities swap to a much colder plug like an Autolite AR472, and put a clear inline fuel filter on your PCV hose between the valve-cover and manifold vacuum.
