OBD II Readiness
Old May 9, 2006 | 06:03 PM
ssrunner's Avatar
Default OBD II Readiness
So at this point I'm in the middle of my HPTuners tuning for a just headers car. I've mostly finished the LTFTs, but I need to be inspected soon, so I turned the MAF back on and all the LTFTs went lean as expected. I'm not throwing a code, but the Evaporative System and Oxygen Sensor Heater tests are still incomplete after about 85 miles of driving. All the other ones are complete. Is that enough tests complete for the computer to be "ready?" If it isn't, how do I get those tests to complete?
For that matter, even if it is enough why don't those tests complete?
Old May 9, 2006 | 08:12 PM
MeentSS02's Avatar
Kleeborp the Moderator™
For those codes, set them to "SES Enabled", "3 - No Error Reported". They should go ready immediately.
Old May 10, 2006 | 10:57 AM
ssrunner's Avatar
Thanks for the advice. It worked like a charm.
Old May 10, 2006 | 11:20 AM
horist's Avatar
Another thing to keep in mind (though this is probably state by state)
2000 and older OBDII vehicles are less stringent (at least in IL they are)
in IL you can have 2 not readies and pass... (for 2000 and earlier), 01+ only 1
Old May 10, 2006 | 11:24 AM
ZL1Killa's Avatar
that goes for NC too
Old May 10, 2006 | 11:26 AM
MeentSS02's Avatar
I do what I can...
Old May 10, 2006 | 04:43 PM
ssrunner's Avatar
Yeah I'm pretty sure you can here too (GA); my dad went crazy and took it in like a week after I deleted all the AIR/EGR codes but before I could check the readiness (was out of town) last year and it still passed. I just wanted to be sure this year.
Old May 14, 2006 | 08:25 AM
KRAZY K 2000 TA's Avatar
I am in NY and trying to figure this out as well we now have a pretty stingent system to pass,I was told that if even my ses light is on it will not pass so since i have HP tuners and my best friend owns the inspection station can i in theory,get the readiness codes to shut off before i plug it in at the station since i dont have to start it?if so what do i change to get the DTCs to be ready to pass?temporaly to do this?
Old May 14, 2006 | 04:55 PM
MeentSS02's Avatar
As stated above:
Instead of "those codes", you can make it read "any code that you are currently setting".
Old May 16, 2006 | 10:18 AM
GuitsBoy's Avatar
Yes, if you effectively disable all the DTCs that correspond to a specific readiness test, it automatically completes. IIRC You can pretty much set every DTC to 3 except the MAF ones.
Old May 16, 2006 | 10:31 PM
Default obdII hah
worked like a charm im in damit! Now if my tires would quit breaking loose when i shift,And i sayith "for torque art my friend and an enemy to my tires for thou art short on life"I love this 402
