Base Running Idle Airflow needs to be 32 to run?
Old May 15, 2006 | 04:14 PM
qwkstang50's Avatar
Default Base Running Idle Airflow needs to be 32 to run?
Can someone please help.. trying to figure out how to get a vette to run with big cam.. only way to keep it running is set the base airflow to 32 g/sec, only then to have it trip a airflow to tp sensor corellation high code and shut off. At this point does this mean i should drill a hole in the throttle plate?
Old May 15, 2006 | 06:30 PM
SSpdDmon's Avatar
Yup...
