PCM Bat Fuse - what does it do?
Anyone know off hand what that fuse is for? Also, should I still be able to read/flash a PCM if it is removed? I'm having some quirky wiring issue with a car, all of my lights stay on if I leave that fuse in, and my ignition switch doesn't do anything. I pull the fuse, and my lights go off and the ign switch works again, and I can turn the lights on/off like normal. I even could read and flash the PCM with that fuse removed.
weird stuff.
It almost sounds like you have a wiring/grounding issue. I've seen loose grounds cause all sorts of issues. Low batteries can also cause odd faults.
Will it start up and run?
You're not using LS1edit, are you ??
If it's the '98, the PCM can get a checksum error stored, and , even though it will seem to program normally, it won't ever work again. That's what happened to mine. I even sent it Jesse Bub to have the PCM recovered, it still would not work.
