slp MAF cal
Old May 19, 2006 | 12:35 PM
KRAZY K 2000 TA's Avatar
Default slp MAF cal
Does anybody have the proper MAF airflow VS. output frequency table for a SLP MAF for my 2000 firebird,i removed the resistor and descreened it also,
Old May 19, 2006 | 02:17 PM
jimmyblue's Avatar
Moderator
Use this truck table:
freq Hz 750 800 850 900 950 1000 1050 1100 1150 1200 1250 1300 1350 1400 1450 1500 1625 1750 1875 2000 2125 2250 2375 2500 2625 2750 2875 3000 3125 3250 3375 3500 3625 3750 3875 4000 4125 4250 4375 4500 4625 4750 4875 5000 5125 5250 5375 5500 5625 5750 5875 6000 6125 6250 6375 6500 6625 6750 6875 7000 7125 7250 7375 7500 7625 7750 7875 8000 8125 8250 8375 8500 8625 8750 8875 9000 9125 9250 9375 9500 9625 9750 9875 10000 10125 10250 10375 10500 10625 10750 10875 11000 11125 11250 11375 11500 11625 11750 11875 12000
flow gm/s 0.2 0.27 0.34 0.41 0.49 0.58 0.66 0.73 0.81 0.89 0.97 1.05 1.13 1.21 1.29 1.59 1.88 2.2 2.58 2.99 3.45 3.95 4.5 5.1 5.76 6.46 7.23 8.06 8.95 9.9 10.91 11.98 13.14 14.39 15.74 17.19 18.74 20.39 22.14 23.99 25.95 27.99 30.14 32.38 34.71 37.16 39.73 42.5 45.41 48.47 51.67 55.02 58.48 62.1 65.86 69.77 73.82 78.06 82.48 87.07 91.82 96.74 101.82 107.08 112.48 118.07 123.83 129.76 135.87 142.17 148.61 155.26 162.11 169.17 176.44 183.94 191.72 199.8 208.06 216.62 225.44 234.52 243.89 253.45 263.21 273.23 283.55 294.15 305.06 316.32 327.93 339.92 352.32 365.16 378.47 392.3 406.7 421.7 437.34 453.69
Old May 19, 2006 | 02:35 PM
how do i change the frequency its lowest is 1500 and it wont let me change that,what year MAF is this from maybe its in the repository
Old May 19, 2006 | 07:54 PM
jimmyblue's Avatar
Moderator
You would just truncate the table to match your OS's
endpoints; they all have the same "axis ticks", just some
go further left/right than others. Pull that table into Excel
and you can select the frequency columns to match your
setup, copy & paste.
The table is one I got off the 'net some while back, it was
purported to be an '02 "ZL1" 6.0 truck, whatever that it.
I prefer it because it's fully populated with sane values
(some clip up top, or have nothing down low). That, and
all my trims are dead-nuts (single digit negative or zero)
with no fiddling.
Old May 20, 2006 | 12:29 AM
dude you had me at truncate o now im really confused and i looked truncate up
Old May 20, 2006 | 08:34 AM
Doc's Avatar
Doc
Hey man I saw your post and just wanted to point out how easy MAF calibration is with EFI Live. I was in the same boat as you. Had an SLP MAF for years, after a few basic mods it made the car go lean. Put the stocker back on. Got EFI Live and a wideband and it is simple. I removed the resistor from the SLP Maf. Next, no excel, just set up the Map in the scanning tool, log data and bingo it will reveal the out of cal factors. Rescale the corresponding values in the tuning tool and shazam you have a MAF that works. EFI Live has everything covered from within it'self.
