Who Tunes With Tuner Cat???? In Here Please
If anyone out there tunes using ner Cat please reply to how do you use the software. I have been trying to get this thing to run better by tunning but have only got moderate gains at best.
A few direct questions are how do you go about setting the shift poinnts for a 3600 stall and what tire diamiter do you use for a 275/50/15 drag radial? Also where is the torque management at on this software?
If you can give me any insit to these questions I greatly appreciate it.
As far as WOT you can make it shift Under transmission tables. Normal and performance mode WOT. Set it for the desired RPM you want it to shift at. As far as driving at part throttle. Each car varys. Play with it. Change settings little at a time. Can also lower the shift time For it to shift firmer.
TM is under the transmission tables. Normal and Performance torque reductions. And under System tables. Under Abuse mode.
http://www.monodax.com/forums/
Is the place to go for Tunercats questions.
