Pos LTFT's w/ MAF..??
Old May 23, 2006 | 04:50 PM
Noy_Z_LS1's Avatar
Default Pos LTFT's w/ MAF..??
Tuning Newb question, I'm sure:
When I scan with my MAF unplugged, My LTFT's read generally between 0 and -7. 2 hours later i plugged my MAF back in and my LTFT's now read anywhere between +9 and +22.
Is this normal? If so do I tune with my MAF unplugged first until my LTFT's go between 0 and -4 and THEN replug the MAF and scale it from there?
Any help is appreciated. THX
Old May 23, 2006 | 05:01 PM
Z'mnypit's Avatar
Have you tried scaling the MAF table?
Old May 23, 2006 | 05:15 PM
Noy_Z_LS1's Avatar
I haven't done any real tuning yet I just wanted to make sure it was normal to have neg. LTFT's without a MAF and Positive with a MAF. I kind of figured I needed to scale the MAF table but wanted to check if I should adjust my Primary VE table first.
Old May 23, 2006 | 05:34 PM
LS1 Sounds's Avatar
My car behaved the same way. I had to scale the MAF table by nearly 6%.
Old May 23, 2006 | 08:38 PM
DEE99TA's Avatar
Yeah, my Ltrims jumped by 10% or so when I plugged the MAF back in. Just scale your MAF table to get it back in the ballpark.
Old May 24, 2006 | 04:17 AM
Shallow Bay's Avatar
How do you perform that?
Old May 24, 2006 | 07:21 AM
RedWS6 00's Avatar
You need to log with the MAF out of the equation first, get your VE table spot on, then plug you MAF back in and re enable, look at the differences and this will be how much you need to adjust your MAF.
Old May 24, 2006 | 07:43 AM
LS1 Sounds's Avatar
RedHardSupra created a spreadsheet to assist with this scaling, but after using it my MAF table was very spikey. I took the average amount of change suggested by RHS's spreadsheet (6%), and multiplied my entire MAF table by 1.06 to bring the LTFTs back in line, but maintain the same MAF *curve* as the stock table.
Old May 24, 2006 | 09:33 AM
jimmyblue's Avatar
Moderator
Clean the MAF thoroughly with an electrical contact
cleaner or some other safe, clean-drying aerosol first;
no point in tuning for spooge. Also, is this or is this
not the stock (virgin?) MAF?
Old May 26, 2006 | 10:42 AM
Noy_Z_LS1's Avatar
Yep, stock MAF with screen.
