what general AFR are you huge cam guys running at? daily driving ranges
hey guys i am curious what kind of AFR you huge cam guys are running at while daily driving..
Thanks
Louie
Thanks
Louie
if operating in closed loop, then stoich (plus or minus whatever over/undershooting your fuel calcs are doing due to overlap characteristics). If OL, you can dial in whatever A/F you like, to the extent that a wideband monitor does not suffer the ill effects of low rpm overlap as well.
15.5ish is supposed to be optimal for gas consumption
14.7 is stoich
11.0-13.0 is for power production (depending on your setup)
14.7 is stoich
Originally Posted by Black02SS
I shoot for 14.5-15.1
I will have to try it out and see for myself of course...
Thanks
Louie
at idle1000rpm(due to shake...not tuning) i am at 15.5...and i love the idle..
but i richened up all the other cells that i would cruise at 1400-2000 and up gets richer and richer and never above 14:1. i richened it up to alleviate some bucking and now i think i may be able to lean it out hopefully to regain a little gas milage.
If i lean it out and still get bucking what are some other options for me to take?
Thanks
Louie
Thanks
Louie
