best spark timing for soparchargchs ????
Old May 26, 2006 | 11:12 PM
NAVY's Avatar
Default best spark timing for soparchargchs ????
hey guys, I want to know what is tha best spark timing for soparchargchs so can i copy high octane table for low octan table or nat
thanks
navy
Old May 26, 2006 | 11:18 PM
jimmyblue's Avatar
Moderator
Playing with forced induction I don't think you really
want to go without knock protection. Why not go
on the tune file repositories and see what has
worked for others with a similar setup? Bear in mind
the '98 also had a known problem with knock sensors,
part type replaced later. But real knock you want to
have something in pocket for, not make the tables
the same. You got a knock problem, fix the problem.
Old May 27, 2006 | 10:32 PM
NAVY's Avatar
thanks
