Pinging!!!
thanks
in my case pulling timing didn't reduce ping, but richening the PE pretty much got rid of it.
Keep us posted.
Maybe you were running the stock High Octane Timing Table
The 1998-2000 cars stock had 28 degs of timing from only 2,400 rpm and above which can be too much if you live in high heat areas, areas of poor octane gas, or have done mods to your car which have leaned the fuel mixture out.
First attachment is the 1998-2000 stock timing table......... I highlited 2400 rpm where the timing is hitting 28 degrees already
Second is the 2001-2002 timing table where at 4400 you only get 19 degs
I'm in So. Cal. and it does get hot during the day, and the gasoline is crappy (it doesn't even smell like gasoline should), besides being limited to 91 only.
(BTW: my MAF is all stock, but I have been switching between MAF-less and MAF'd week-by-week).
Once your fueling is in line, try zero-ing out the burst knock table, load the stock high spark table, copy the stock high table to the low, and bump the KR Recovery rate to 0.05. Tordne and I swear by getting rid of the burst knock table over in the EFI Live forums. I have had ~90% less KR since I've done that. If you're still seeing KR after that, I'd pull the timing down a little in the affected areas. If not, restore the stock low table and enjoy.
I find that trans. seems to depend on engtrq which is computed from airflow/airmass, so as long as ve table and maf table are correct then trans. is fine in each mode, I verified this in my logs (tfmprs is as expected).
I'll do the burst knock thing over the next few days.
Close again...they actually hit 29 degrees at 3200rpm, drop back down to 23 degrees at 4800rpm and return to 28 degrees by 5600rpm.
Yes, I know....... I was just generalizing. But for specifics I posted the high octane spark table attachments for reference.
Any way to send the EFILive spreadsheet my way? I would be interested in what you are doing. Also which wideband do you recommed to use with EFILive?
Thanks, Greg
