O2s flatlining-railing, I just cannot figure this out
You can then see in the 2nd attachment of where the histogram shows that its lean on the low map areas on the decels. I exported the histogram and looked at it in excel after sorting the data and noticed that the 2950-3050hz range has LTFT values of +8 alot. But then at the same time the same range also shows alot of -8 values. So its like if I bump up the calibration for that Hz value on the MAF calibration table, then I will just make it really rich for the areas that its already showing -8.
I have SVO30 injectors in there and my calibration is definetely correct. I used to have the 60lb mototrons in there and was seeing similar problems but at a much larger scale where the O2 would flatline or rail for alot longer period and would get -30 LTFTs.
I just cannot seem to figure this out. What am I doing wrong?
Here is the scan file and HPT tune to look at.
http://www.turbofedmax.com/Z06vette/...HPTandScan.zip
Ive also noticed that in SD mode it doesnt do this where I see Lean LTFTs in the low MAP areas and Rich in everything else.
Dixit
Dixit
13.00000 16.00000 25.00000 50.00000 50.00000 50.00000 50.00000 50.00000 16.00000
26.00000 33.00000 50.00000 50.00000 50.00000 50.00000 50.00000 50.00000 16.00000
Dixit
You can then see in the 2nd attachment of where the histogram shows that its lean on the low map areas on the decels. Dixit
I seem to notice that in SD that it runs fine, dont get these lean cells, its perfect in SD where I got everything between 0 and -4. I just dont understand why the MAF wont get to that. Ive noticed the 3000hz is the ones that is causing this, but when I raise the calibration for that I fix the low MAP areas but then my idle (which also floats at 3000hz) ends up being -10 LTFT.
Dixit
Using the injector flow calculator if your injectors are rated at 30#s @ 43.5 (3 bar) then your IFR table should go from ~34-37.
Dixit
36.14916 36.33518 36.58320 36.76922 37.01724 37.26526 37.45128 37.69930 37.88532 38.07133 38.31935 38.50537 38.75339 38.93941 39.18743 39.37345 39.55946
Check the rating for the injectors. Some injectors are flow rated at 3 bar, or 43.5 lbs. Not sure how much difference this will make, but if the injectors are rated at 43.5, then your current numbers will cause you to run a bit leaner.
I've found the offset/volts/kpa table to have the biggest affect on fueling, after the IFR table. It looks like these values are dependent upon the type of injector, rather than the flow. For example, my 42 SVOs liked one setting where my 42# Delphi's wouldn't run well with the same setting. If you PM me your email I'll send you the tune that worked well for my SVOs. You can copy the offset/volt/kpa table from there.
I then tried values of the SVO30s from say a Ford ECU where someone converted the values and used that map, and saw my LTFTs go from almost being spot on to about -30. So I knew that didnt work. I attached the spreadsheet some guy made, that I used for the SVO, never worked.
Dixit
