MS3 going in, any tuning tips?
. From my previous F14 tuning experience, Riddlerls1 is right, I won't attempt to tune without a WB, its just too much of a PITA.Good luck,
Kevin
I have the same cam in my z06 and love it. I would not even try to tune it without the wb. If its your first time it will just take some time but in the end you will enjoy the way the car runs. I have stock idle and the car still drives the same just has more power, and my gas mileage went up also. Good luck.
ohenry_28311@hotmail.com
i think its a bit much for my car because i get a bit of cruse controll but it aint bad
BTW ls1poweredz28 do you mind sending me a copy of your tune when you finish ?? im paticularly intrested in your cold idle portion being mine is still a bit rough
Kevin
My rpm's swing to low @ approx 25 mph after quick blip of the throttle. In others words say 25% throttle to 20-25 mph, off the gas pedal quick, the rpm's will drop low then swing back up where they should be.
Thanks in advance!
