Timing on bigger cams
Jim C.
Filtered RPM Airflow Correction
Learned Airflow Correction
and
Direct Airflow Correction
The hunting idle my friends A4 was experiencing went away after that. Hopefully you can find the corresponding tables in HPT. They were under the Engine/Idle/Learning folder in my software.
and
If I close my set screw any more my counts will go to zero. My counts never exceed 50 and are closer to 20-30 after it warms up. I will look for the tables that you mentioned. I have my timing up to 41 in the problem area and have made it a touch rich in those areas as well which seems to have helped but I want the bucking gone. I took like 20% out of the cracker table which I am not sure if that did anything at all.
hehe we took it up to 45 degrees for ***** and giggles... no knock but iddn tsee any better response so we took it back down
Jim C.
for bucking .... try adding soem fuel..its almost always a lean condition when its bucking..timing is most likely not yoru solution...
http://www.hptuners.com/forum/showth...0336#post50336
I had this thought this morning when I woke up.
I was thinking that perhaps the reason that I can't seem to get it dialed in perfect is that I am only getting the WB02 readings from one bank. I have true duals that are not crossed over in anyway. 2 independent exhaust pipes. Is it possible that bank 2 (passenger side) is leaner or richer than bank 1 and therefore I am not tunning an average of the 2 sides?
