Auto tranny pcm on m6 car?
Old Jun 8, 2006 | 08:46 PM
digitalsolo's Avatar
Default Auto tranny pcm on m6 car?
Will an auto tranny pcm cause problems with an m6 car? We're trying to get a tune on an ls1 rx7... the motor/tranny is a 99 camaro setup, but the wiring harness and ecu are 00 silverado. Obviously, the silverado was an auto. We're having a bunch of weird issue... we can get a solid tune at idle, but as soon as we drive the car everything goes to hell. We're throwing a ton of tranny codes. Is there something we need to change to make the auto tranny ecu cooperate with the manual tranny car?
Old Jun 8, 2006 | 09:07 PM
indyparts's Avatar
...bump
Old Jun 8, 2006 | 10:08 PM
Schitzo's Avatar
you need a M6 program on the PCM. I had a PCM out of an A4 so I sent it out to wait4me and they reflashed it with the right program for the M6
Old Jun 8, 2006 | 10:21 PM
indyparts's Avatar
This problem is acutally with my car, but was posted under Digitalsolo's name. I have accessability to HP Tuners and can flash the PCM myself, but I am not sure what all has to be done. What problems will running a A4 PCM on a M6 cause.
Old Jun 9, 2006 | 02:25 AM
Tordne's Avatar
The PCM should be no issue at all. All you need to do is get a file/tune from a M6 car and flash it in, and then start your tuning
The PCM is just a computer and the tune is the program. I think the 512kb PCM is the same across Corvette, Camaro and even Holden.
Old Jun 9, 2006 | 04:48 AM
RedWS6 00's Avatar
I have a 2000 LS1 M6, have a stock bin file I can email you if that helps. Send me an email and I'll get the bin file emailed.
Old Jun 9, 2006 | 08:01 AM
wait4me's Avatar
Do a search for about 2 years ago, I did a full instruction on this site or ls1.com. You will need to run some wiring to get some things to work back as usual, but it was a very simple project.
