Negative LTFTs at WOT, Fix???
I can email anyone the graph of this taking place as a powerpoint file if this would help. Thanks, Brian
I looked at all the sensors that I can think of would cause this and they look great. What gets me is that when this takes place all the sensors stay the same so it makes me think it is tuning related, but I don't know. I notice my lights dim when I go WOT. Could this have anything to do with the negative LTFTs? I think it is from my belt slipping on the alternator.
The dimming at WOT, I think, is a separate issue (unless, of course, the controller supply droops below 4 volts, but I think the car would just shut off then). That's odd... in and of itself. Perhaps a slipping belt.
Please check the FTC at WOT.
Also check the PE enable table. Always possible a wrong value has been entered forcing it to stay in closed loop.
If you have a contiguous stream of data with TP% at 100 and the FTC is not steady at 22 (without being in a "transition" region, i.e., shift), then there's something that is overriding the PE Enable TP% vs. RPM table. That's probably the first place to check. Have you done something with the tune, recently, to cause these issues? However, if you have a contiguous stream of data with TP% at 100, FTC at 22 and LTFTs at -15, that's a problem that would extend beyond the capabilities of any tuning software, that I know of, to deal with. There may be a problem with the PCM. I hope that's not the case.
I hope all this rambling is helpful and not confusing. Good luck!
