I may have murdered my pcm
Old 06-10-2006, 02:12 AM
jazzz007's Avatar
Default I may have murdered my pcm
Installing a shift light and something went wrong. Now i have no fuel pump, or fuel gauge, or speedo, or temp gauge, or 1st gear or overdrive. There may be more i just afraid to look. DTC says P0748 solenoid has seen a ground. Someone with the knowledge help. Have I fried the squash or is it just a simple reset i don't know about? all fuses look good but prob need to use a tester. Any help will b appreciated.
Old 06-10-2006, 08:02 AM
ringram's Avatar
Disconnect all your wiring that you added for the shiftlight and check the other cables, wires, connectors etc. Do a PCM fuse pull and try again. Maybe you just grounded the wrong wire or something.
Old 06-11-2006, 12:10 PM
Bill Bowling's Avatar
Talking
Did you find out what your problem was?
Bill
