Code P0300 ?? What to do??
Old Jun 10, 2006 | 01:27 PM
Bowtiejoni's Avatar
Default Code P0300 ?? What to do??
Hello !
I have a LS6 as an retro fit in old vette. Wiring and pcm is from Spearteach and everything seems to working good.I have all parts brand new gm. Except plug wires wich are from callaway-header models. I know the code is multiple missfire but egine idles really smooth.
Any ideas what to do ?
Old Jun 11, 2006 | 07:54 AM
98A4LS1's Avatar
I wish I could help. I've been trying to resolve cyl misfires for 3 months. TTT for you.
Old Jun 11, 2006 | 08:31 AM
blackdogz's Avatar
A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Old Jun 11, 2006 | 09:05 AM
227Hawk's Avatar
Stock camshaft in motor? Almost any aftermarket cam that is larger then stock will produce the same PO300 codes
Hawk
Old Jun 12, 2006 | 11:25 AM
Bowtiejoni's Avatar
Thank you all for your help! I think John fixed my problem!!!
Old Jun 13, 2006 | 05:03 PM
prostock_bigblock's Avatar
what was the problem??
Old Jun 13, 2006 | 08:24 PM
AdamSS's Avatar
yea, what was the problem ?
Old Jun 16, 2006 | 03:39 PM
BADSZ28's Avatar
So if most cams cause this then how do they fix it? I am getting the same thing.
 Michael S. Palmer
