MAF issue Code P0102
Old Jun 11, 2006 | 06:41 PM
BBBBadSS's Avatar
Default MAF issue Code P0102
Code P0102. It read maf low input. I tryed a new maf sensor. It was a new granatelli 85mm. Had the code erased and it come back. Sold granatelli and put stock back on. Anyone else have this problem? Any suggestions?
Old Jun 11, 2006 | 07:15 PM
Noy_Z_LS1's Avatar
could be a bad connector to the MAF or a grounded/cut wire from your MAF. Not sure though, becuase these issues would prob throw a P0101 code also. Maybe someone can else can chime in, but take a look at your connector (might need cleaning) and wires.
Old Jun 12, 2006 | 09:39 PM
68ss_00ss_87_95's Avatar
i got the same code.....at higher rpms it feels like its slowing down....i checked my wires/connector....didnt try my granatelli yet although im sure it wont help...i pulled up the trouble code checklist here and it told me to check pcv and such..havent had time to play with car yet so ill see if i can tomorrow...if you modified your pcv or any of that crap check them again... im still searching for the answer
Old Jun 13, 2006 | 08:48 PM
BBBBadSS's Avatar
Had the pvc system off when I did a fast 90 install. Code was already there before that though. Dont't think it's anything there unless it's a bad pvc valve. How do you know if the pvc valve is bad? Also checked the connector.
If it was a bad map sensor would that have it's own code?
