About to get a tune, what to do?
Only reason to get a mail order tune would be to get the car to at least run and be in 'safe mode' after an install - just to get you to the shop that is gonna do the proper dyno tune.
Unless you know of a shop that will install a WB O2 setup for you & drive around in your car with a laptop and log your values - then tune - go back and drive again - the tweak tune, etc.
They could change paramters such as !EGR, !A.I.R., Fan Settings, Tranny Settings at a shop from a laptop (or you could do some of those items yourself using a Diablo Predator Handheld Tuner for eg.) - but to properly tune the engine you will need the WB O2 readings.
If you are going to do major mods other than bolt-ons you should always plan on $500 for a good thorough dyno tune in your budget before doing any of the modifications. It sounds like a lot right now, but depending on what parts you have installed it could mean the difference between a sweet running, powerful engine and a blown engine!
i really don't know.
learn yourself and ask others online using LS1Tech.com!!!
if you are near charlotte, I recommend Nick Williams or Alvin@pcmforless or Mike (WS6FirebirdTA00) up on these boards.
near raleigh i would recommend RPM (Ryans performance machines)
CAM(carolina motorsports)- can sometimes be bad, but recently had 2 guys go there and there cars put out some good numbers so I will no longer say its bad.
and BTW Girls =
thanks
