question about tps voltage
Old Jun 14, 2006 | 12:04 PM
Summit2345's Avatar
Default question about tps voltage
i was wanting to know what kind of voltage i should see when i check my tps also just double checking which wire should show the voltage
Old Jun 14, 2006 | 12:16 PM
RedWS6 00's Avatar
I beleive you should see 0V and 5V on two of the pins. One will vary on TPS, should read between 0 and 4.6V, 4.6V being WOT. If you read much more than 4.7V will give a TPS error showing up as an error code.
Old Jun 14, 2006 | 02:51 PM
Shallow Bay's Avatar
https://ls1tech.com/forums/showthrea...hlight=writeup
