Help with Gauges!
thanks for the help Since the gauges go to "zero" without power, you can try to install the pointers at their min location. I wouldn't get to freaked out considering the stock gauges aren't very accurate from the factory. You might just luck out and get closer than GM did.
If you're inclined, you can always try to reconcile the gauge values with a scan tool.
