car not starting
Old Jun 18, 2006 | 05:19 PM
Wnts2Go10O's Avatar
Default car not starting
ive just finished a cam swap and am getting fuel and spark. also it is fireing but no enough to idle. i can tell because the header tubes ar ewarm and the popping that happens when i try to start it. im am completely stumped and have no clue wht it could be.
Old Jun 18, 2006 | 05:58 PM
ZL1Killa's Avatar
does the motor start to turn over and then die? or does it just not run at all?
how big of a cam did you do? ever think of the desired airflow after the cam install? you might need a bigger hole in the throttle blade or to crack the throttle open some, could be suffocating her.
Old Jun 18, 2006 | 07:00 PM
Wnts2Go10O's Avatar
it jus kinda pops a little bit but doesnt get labored or anything. its just a TSP T2
Old Jun 18, 2006 | 07:25 PM
Wnts2Go10O's Avatar
i tried holding the throttle open at 4-5% and still nothing, jus a few low, low pops and thats it.
Old Jun 18, 2006 | 09:05 PM
ZL1Killa's Avatar
somethings wrong, hate i can't tell you more
Old Jun 18, 2006 | 09:31 PM
Wnts2Go10O's Avatar
i wonder what it is thats doing this.
Old Jun 18, 2006 | 10:03 PM
ZL1Killa's Avatar
how did you know how to do the cam swap? is everything lined up like it was when you pulled the cam out
Old Jun 18, 2006 | 11:09 PM
Wnts2Go10O's Avatar
put a new timming set on and the dots are where they should be. the screwed up thing is the chain had to be stretched to get the cam gear on. if its like a half tooth off im gonna be pissed. the preload is 1 1/4 turns total. so heres where im stuck
