Need ideas on rich startup problem
Problem: The tune the car came with has it running perfectly except for initial startup. The car will turn over and fire, but will die almost immediately if you don't give it gas, and while it attempts to run in open loop you can't let off the gas or it'll die. Meanwhile it's spitting/coughing and bellowing black smoke out the exhaust, so I know open loop has to be rich as hell. Once close loop kicks in the idle stabilizes and settles right at the commanded 900rpm. I've tried scaling afterstart enrichment by 50% and more with no luck. Also tried setting OLFA table to 1.00, no luck. I haven't had the car for more than 5 mins at a time, so I haven't been able to scan to see what commanded afr is at startup, hopefully I can do that one night this week. I figured leaning out startup enrichment would fix him right up! Any ideas? Thanks guys!
Also scan his IAC counts, I think I read something a while back about the BBK's not having a hole in the TB from the manufacturer.
Do your first 3 columns in your VE table match a stock file, compare them, they should be a lot different.
Good ideas, I'll check it out tonight if I can get ahold of the car. I wish he had more info about the mods from the PO. I don't think the injectors were replaced but I haven't checked the IFR table yet either.
MAF table had been modified to '01-'02 calibration too, still ran like hell. The Best V8 Stories One Small Block at Time
