Too much fuel?
Old Jun 21, 2006 | 10:57 PM
brokez's Avatar
Default Too much fuel?
Ever since I installed walbro 255 in-tank car shuts down around four grand if I floor it.But if I slowly increase throttle it won't shut down.The car was tuned for the 100 shot and was leaning out bad so my tuner told me he was going to push the stock pump as hard as he could so I was thinking I just need a retune cause it's just dumping to much fuel in when I go wot.Does this theory make any since?
Old Jun 22, 2006 | 07:58 AM
brokez's Avatar
T T t
Old Jun 22, 2006 | 03:55 PM
white2001s10's Avatar
You'll have to check your fuel pressure at some point.
You might have a pressure leak inside your tank.
Old Jun 23, 2006 | 07:50 AM
brokez's Avatar
T T T
Old Jun 23, 2006 | 04:43 PM
technical's Avatar
Sounds reasonable. Get the fuel pressure checked first, then check the tune.
