wtf? did my car somehow loose its tune?!
Originally Posted by 00transamnh
huh? please elaborate
Originally Posted by ZL1Killa
just keep us posted guys, if you can't tell i'm here a lot
They missed that EGR code and the car is loading up on the street which set's off the other codes. The tune is just way off.I've been seeing it alot lately by these tuner's popping up everywhere.Sucks fixing other shop's tuning constantly
#32
alright... so i was thinking Maybe im choking the air out of my engine at idle
What if i just didnt drill my throttle body hole big enough. Should i drill it out more? Will the larger hole mess up my current tune?
#33
#35
tuning was done on a dyno but i dont know the first thing about tuning so...
If it was only dyno tuned on a non-load bearing dyno there is no way it would be tuned right.
meaning - It was tuned for WOT A/F and timing. Then you take the car off the Dyno and the tune goes off again because the L-terms start to relearn.
This is a big If. but I've been seeing it alot lately around here.Myself and some other shops have been getting these cars to retune them the correct way. Not saying your's is like that,just a possibility. That would explain the problems you are having.
#36
"tunes" cannot be lost. Tuning software does not add the new values on top of the stock data, rather it completly rewrites the data segment and there's no other value for it to default back to.
Anything could of happened. He could of forgot to save the changes, loaded the wrong file into your pcm ect.
#37
i dunno if this will help any but in the recent hot weather up here in the north east i started using my a/c
the car WILL NOT idle at all if the a/c is on. The only way to keep it running is to keep my foot on the gas (Even then its tough to keep at a reasonable rpm)
#38
i think that it is possible to loose a tune or part of it anyway. my friend had his car tuned and we did a power balance test with a gm tech 2 to find a skip. and he had the speedo turned off. the minute after we unhooked the tech 2 and drive it the speedo was back working.
