Trying to Set Idle Higher?
Old Jun 27, 2006 | 08:47 PM
98SS1LWEE's Avatar
Default Trying to Set Idle Higher?
Okay, i jsut wanna bump my idle up a bit. Any easy ways to do this? I have a HPP, but dont even know if it's an option with it. Any other ways?
Old Jun 27, 2006 | 09:14 PM
ZL1Killa's Avatar
you cannot do it with the programmer. you will need EFI LIVE or LS1edit
I'm on a friends computer now, but I can tell you the tables when i get home
Old Jun 28, 2006 | 07:51 PM
98SS1LWEE's Avatar
What about HP Tuners? WIll it work, i ahve a chance to get one cheap, it has a 1.4 version disc for 98's and a cd-r with 1.5 version supposedly.Does this sound right?
Old Jun 28, 2006 | 10:43 PM
ZL1Killa's Avatar
talk to www.hptuners.com
make a post and register.... go for it, as I have EFI LIVE and i don't know a lot about HPTuners, but i believe it will do it
Old Jun 30, 2006 | 01:47 AM
TylerDurden28's Avatar
I got my car tuned tonight by a HP Tuner and before the tune I was right at 500RPM's and now im around 750RPM's, so it can be done.
Old Jun 30, 2006 | 02:28 AM
ringram's Avatar
Set screw wont work properly unless you go past IAC ability to pull air. Proper fix is PCM idle speed change.
Old Jun 30, 2006 | 08:18 AM
SSpdDmon's Avatar
The idle set screw is a torx bit T-10. However, as stated above you need to do it through the PCM. There's a table (that should be in all versions of LS1Edit, HPT, EFI Live) that allows you to adjust desired idle speeds based on coolant temps. The newer cars also have a run timer that will add rpm to the desired idle speeds for 20 seconds after startup before slowly decaying away. I think '01 was the first year they used this on LS1 f-bodies.
