Idle and start up problems. please help.
Old Sep 4, 2006 | 11:33 AM
SUX2BU's Avatar
yeah still having problems. Email me nino. juanfgalaviz@yahoo.com
Old Sep 4, 2006 | 01:12 PM
ninobrn99's Avatar
email sent.
Old Sep 5, 2006 | 04:17 PM
SUX2BU's Avatar
Originally Posted by LS1 Sounds
I've only tuned one H/TRex/TH400 car so far, but was able to get it to start/idle/drive surprisingly great at 900rpms without drilling the TB. Base running airflow (RAF) was increased a LOT, also Startup airflow was added as well. VE was decreased <= 1600rpm, and timing was added. Idle overspeed spark values were cut in half.
i'm a retard when it comes to tuning so could you explain this.
Old Sep 5, 2006 | 04:32 PM
V6 Bird's Avatar
Originally Posted by SUX2BU
Ok my car has a tune in it and it drives great. My only problems are that it sucks *** on start up. I have to give it gas and slowly back off of it everytime i start it or else it won't idle. Even when at full operating temp.
Also if i stab the throttle even a little bit or just let off in first or second (RMVB th350 so 1st and 2nd have engine braking, its like being in neutral when i let off in 1st and 2nd) it dies.
I have the idle set at 950 with the IAC counts at about 30-40 in N/P and about 70-80 in gear. It also surges a little in N/P.
Its an M6 computer with a th350 tranny so it doesn't have in gear idle/ P,N idle differences.
I have Hp tuners available but have no clue where to start.
Not to be a dick but I thought Brian was your boy and that **** was perfect? Now, I see this...seems its not always greener on the other side now is it?
Now that im done with the ribbing...dont mess with anything until you can find your stock VE table to compare too...id flash back to the stock one and log it to see what the car wants...but before you do that...the car needs a WIDEBAND on it before any changes are made at ALL! You need to see how rich it is now. Im guessing somewhere in the drowned area of AF ratios since its an RPM idle tune we are talking about.
Old Sep 5, 2006 | 06:16 PM
SUX2BU's Avatar
It was. but at 75 mph it would pick up and then bogg down. it felt like it was pulling timing so i logged it with my tech 2 and it wasn't. the O2 readings were at like 100mv and they weren't bouncing back and forth like they should. they would jump to 900mv whenit felt like it was picking up. long story short it was starting up and idling good cause it was in open loop the whole time. got it to where it goes into closed loop again but now its having the same original problems. Brian is helpin me try to figure it out but i'de like to try to do it my self so i don't have to keep driving up there.
i do have a stock tune. to compare to. just don't know what to do.
Right now the #1 priority is to get it to start wihout having to play with the throttle and idle in nuetral/park without surging.
Old Sep 5, 2006 | 06:35 PM
LS1 Sounds's Avatar
Try some of the following settings to cure the problems you are having at startup and low throttle. Unfortunately I didn't tune anything other than idle/low speed driveability, the rest was done by someone else on a dyno. Also, the guy's car that I tuned had dead O2 sensors when we started so he replaced them with the Vette's rear O2 sensors (Bosch 13111's). I'm also not sure what size converter he was running.
Also you can email me your tune if you'd like and I will try to take a look at it. The address is chad AT dodds DOT cc:
Engine > Idle > Idle RPM > Target Idle Speed
Code:
1150.00003	1150.00003	1150.00003	1100.00002	1100.00002	1100.00002	1100.00002	1000.00002	900.00002	900.00002	900.00002	900.00002	900.00002	900.00002	900.00002	900.00002
1150.00003	1150.00003	1150.00003	1100.00002	1075.00002	1050.00002	975.00002	925.00002	900.00002	900.00002	900.00002	900.00002	900.00002	900.00002	900.00002	900.00002
Engine > Idle > Idle Airflow > Base Running Airflow:
Code:
24.20020	30.34961	30.09961	28.12305	25.99902	24.00000	22.97754	19.00000	16.58691	15.00000	14.40039	12.94629	11.71973	11.71973	11.71973	11.71973
Engine > Idle > Idle Airflow > Startup Airflow Decay:
Code:
0.400
Engine > Idle > Idle Airflow > Startup Airflow Initial:
Code:
5.00000	3.50000	3.00000	4.00000	4.00000	4.00000	3.00000	3.00000	3.00000	3.00000
Engine > Idle > Idle Airflow > Startup Airflow Delay:
Code:
100.00000	100.00000	100.00000	100.00000	100.00000	100.00000	100.00000	100.00000	100.00000	100.00000
Engine > Airflow > General Airflow > Primary VE (colums 0 - 1600 only):
Code:
30.93538	31.62424	32.67732	39.73220
33.48495	40.13602	42.03632	47.10380
38.91665	43.86536	47.84017	50.19180
40.78529	46.33576	50.35015	52.70178
42.16301	47.71348	51.56952	54.07950
43.54073	49.09120	52.54342	54.76836
45.20350	50.35015	53.27187	55.49681
46.13781	51.24488	54.00032	56.18567
47.06421	52.17128	54.93464	57.65049
46.73958	53.23228	56.02731	58.74317
47.10380	53.59651	57.04081	60.23966
47.51553	54.00032	58.45812	61.61738
47.84017	53.43023	59.10739	61.98160
49.17830	54.72877	59.87543	62.75756
50.51643	56.10649	61.05520	62.99510
51.15778	58.33935	62.43292	63.24055
53.02642	60.23966	63.81065	64.61827
54.88713	62.06870	65.22796	66.03559
Engine > Spark Control > Spark Advance > Idle Spark Advance (In Drive):
Code:
30.00000	30.00000	30.00000	30.00000	30.00000	35.01099	37.27473	38.00000	38.32967	38.35165	38.13187	37.78022	37.34066
30.00000	30.00000	30.00000	30.00000	30.00000	34.37363	35.67033	36.39560	36.72527	36.72527	36.50549	36.17582	35.82418
30.00000	30.00000	30.00000	30.00000	30.00000	32.63736	33.97802	34.68132	34.94505	34.85714	34.61538	34.30769	34.08791
30.48352	28.74725	28.81319	25.69231	29.14286	31.45055	32.85714	33.58242	33.75824	33.62637	33.31868	33.05495	32.98901
24.57143	24.57143	26.50549	24.10989	28.02198	30.61538	32.15385	32.90110	33.03297	32.81319	32.46154	32.17582	32.17582
19.64835	19.64835	20.39560	21.01099	26.00000	29.93407	31.67033	32.48352	32.61538	32.32967	31.84615	31.42857	31.29670
14.39560	14.39560	14.39560	20.00000	25.01099	28.00000	30.00000	31.01099	32.00000	32.00000	31.29670	30.54945	30.98901
12.30769	12.30769	12.30769	19.34066	22.00000	27.01099	29.01099	30.00000	31.01099	31.01099	30.61538	29.31868	28.92308
10.30769	10.30769	10.30769	16.17582	19.78022	22.61538	25.01099	27.34066	27.34066	27.34066	27.34066	27.49451	27.51648
8.00000	8.00000	8.00000	13.01099	15.01099	17.01099	18.00000	21.01099	24.17582	24.61538	24.85714	25.07692	25.45055
8.00000	8.00000	8.00000	11.38462	12.50549	15.01099	16.50549	18.00000	19.01099	22.00000	23.34066	24.39560	25.16484
8.00000	8.00000	8.00000	10.00000	11.01099	12.50549	15.01099	16.00000	17.01099	18.00000	20.72527	22.74725	24.06593
7.71429	7.71429	7.71429	7.71429	7.71429	9.47253	12.61538	15.38462	17.01099	18.00000	18.90110	19.95604	21.91209
7.71429	7.71429	7.71429	7.71429	7.71429	9.47253	12.54945	15.23077	17.01099	18.00000	18.90110	19.71429	21.01099
7.71429	7.71429	7.71429	7.71429	7.71429	9.47253	12.54945	15.23077	16.83516	18.00000	18.90110	19.49451	20.30769
7.71429	7.71429	7.71429	7.71429	7.71429	9.47253	12.54945	15.23077	16.83516	18.00000	18.90110	19.49451	19.49451
7.71429	7.71429	7.71429	7.71429	7.71429	9.47253	12.54945	15.23077	16.83516	18.00000	18.90110	19.01099	19.01099
-Chad
Old Sep 5, 2006 | 07:29 PM
V6 Bird's Avatar
What you are experiencing is a combination of a few things Juan...a bad VE table for starts and like the guy above me is posting...some spark table issues as well.
His tables look real good for what you need at first glance. Some fine tuning here and there once you get an idea of where the A/F is at once you make the changes his taken screen shots of.
Old Sep 6, 2006 | 09:00 AM
kenkaru's Avatar
I don't have any idle tuning tips but that post by LS1Sounds is pretty nifty with all the scrollbars and stuff. Never seen anyone do that before.
Old Sep 6, 2006 | 09:04 AM
LS1 Sounds's Avatar
Thanks! It was done using the [ CODE] tags. I didn't want to clutter up the thread with all of those numbers...
-Chad
Old Sep 6, 2006 | 04:37 PM
SUX2BU's Avatar
-Chad
Alright put all that in the tune. gonna go put it in the car and cross my fingers. thanx.
Old Sep 6, 2006 | 05:07 PM
LS1 Sounds's Avatar
Let us know how it works out! I just talked to the guy that owns the TRex car mentioned before, and it's still driving great.
Old Sep 6, 2006 | 05:34 PM
  #32
SUX2BU's Avatar
Surges pretty bad at idle and it'll start right up sometimes and not start at all other times.
When i put it in gear (with my foot on the brake) it surges and actually rolls forwards during each surge untill it calms down.
Old Sep 6, 2006 | 05:40 PM
  #33
SUX2BU's Avatar
i'm gonna drive it around a couple of days and see if it gets any better.
Old Sep 6, 2006 | 09:16 PM
  #34
LS1 Sounds's Avatar
Can you make a log of startup and idle during warmup, and send to chad AT dodds DOT cc? Use this config for logging:
http://ls1sounds.com/temp/Chad_Idle.cfg
Old Sep 7, 2006 | 04:52 PM
  #35
SUX2BU's Avatar
What about "IAC steps vs. Effective area" ?
This says to multiply it by 1.48. it that right? i have a TPIS 90 mm TB.
http://redhardsupra.blogspot.com/200...le-tuning.html
Old Sep 7, 2006 | 06:57 PM
  #36
LS1 Sounds's Avatar
Yes! You definitely want to do that, I didn't know you had the 90mm.
Old Sep 11, 2006 | 07:53 PM
  #37
SUX2BU's Avatar
Are the LTIT's supposed to be 0 all the time?
Old Sep 11, 2006 | 08:17 PM
  #38
SUX2BU's Avatar
Sent you an email but it didnt go thru. its chad@dodds.com right?
Old Sep 11, 2006 | 08:43 PM
  #39
LS1 Sounds's Avatar
Nope, sent you a PM.
Old Sep 11, 2006 | 08:54 PM
  #40
SUX2BU's Avatar
sent.
I changed the RAF and raised the idle to 1100 so it would idle without surging. now it stummbles a little when i start it but it starts about 75% of the time by itself.
