HP Tuner help
Old Jul 5, 2006 | 11:54 PM
ramair21's Avatar
Default HP Tuner help
How do you enable the air pump. I can control this by turning on the air pump on the on/off selection. But when i turn on the car it wont work?? My current setting is 14F on the ECT thing. is this right??? or is it disabled
Old Jul 5, 2006 | 11:58 PM
BigE's Avatar
14 F is the stock setting. What makes you think it's disabled?
Old Jul 6, 2006 | 12:05 AM
ramair21's Avatar
cause when i turn the key to on the PCM does not ground PCM 36 which goes to the air pump relay. But when i go to the on/off mode on HPT it works???
Old Jul 6, 2006 | 01:22 AM
ramair21's Avatar
When does the PCM ground this wire??? As soon as the key is turned or when the motor starts up??? ANy light on this guys cause i just see pitch black!!!
Old Jul 6, 2006 | 08:35 AM
BigE's Avatar
I believe it only starts the AIR pump after the engine has been started. Is the engine in running condition?
Old Jul 6, 2006 | 09:27 AM
ramair21's Avatar
not really, have open headers and the battery is dead. Need to charge. I will charge the battery and work with this. Thanks bro
Old Jul 6, 2006 | 11:04 AM
soundengineer's Avatar
try setting air pump enable temp to 284...
shouldnt be causing a problem...
I've tuned hunderds of cars that have had headers and no air or egr..and no problems....
you may have some other kind of ghost in teh car you should be chasing...LOL
Old Jul 6, 2006 | 10:24 PM
ramair21's Avatar
so 284 is to enable the air pump?? I thought it was 14???
Old Jul 6, 2006 | 11:47 PM
stock setting is 14...
I'm telling you to disable the air pump by setting the turn on temp to 284...
I misread and now see that you want to turn it on....
so set it to a low value...stock should be plenty low though
