Altitude changes
Old Jul 6, 2006 | 07:43 PM
Mr. Luos's Avatar
Default Altitude changes
I am tuned at 5400 feet.
Looking to run at 630 feet in a couple months.
Issues?? Or will the computer learn?
N/A if it matters.
Old Jul 6, 2006 | 08:10 PM
slow's Avatar
If your tuner tuned the maf correctly, you will be fine.
If they did not, then you may have issues.
Ryan
Old Jul 6, 2006 | 10:13 PM
bradz24's Avatar
mr luos.
I have done this ..went to 500 ft. from Denver. and I have been fighting my idle on and off. its getting really close. . my AFR looks pretty good just the darn idle. besides the idle my car did learn the new altitude pretty good.
Old Jul 6, 2006 | 10:31 PM
Street Lethal's Avatar
Agreed. If you're running a Speed Density tune however, and eliminated the MAF entirely, you'll definitely run into an issue or three....
Old Jul 6, 2006 | 11:10 PM
SmokingWS6's Avatar
If your tuned for SD, it'll be quite lean.
Properly tuned maf, afr should not change.
Old Jul 7, 2006 | 08:22 PM
Mr. Luos's Avatar
Okay.
It isn't SD, so good there.
Idle may need adjusted, safe just to use the screw on the TB to help it find idle?
I won't have any software with me. At least I don't believe I will.
Old Jul 9, 2006 | 01:17 AM
SmokingWS6's Avatar
Originally Posted by Mr. Luos
Okay.
If anything the iac won't have to open as far to control idle with the denser air. It should be fine as is.
Best of luck with faster times in the thick air
