Bs3??
Old Jul 7, 2006 | 08:54 AM
MKGTO's Avatar
Default Bs3??
from the searching i've done it seems the BS3 is going to be the better option to buy, but there's still a few question that need answering, hopefully that's where you guy's come in
is the Bs3 compatible with all the ls1 (2004 pontiac gto) sensors?
can it be used with a map sensor or do you have to retain the maf instead?
i'm going to be installing the engine in to a different car so am only using the engine and 6 speed manual transmission, there's no a/c or power steering. At the moment all i need the Bs3 to do is make the car run and give an output for the fan, fuel pump and tacho signal. From what i've read it seems it can do this and more no problem, does the Bs3 come with a basic loom or is best for me to chop the existing ls1 loom?
last question at the moment is, which company am i best to buy it from? it will need shipping to the Uk.
Thanks for any help
Chris
Old Jul 9, 2006 | 03:48 PM
Tompi's Avatar
I bought my BS3 from W2Wpowertrain, their customercare is all you can wish for. I highly recomend them.
/Tompi
Sweden.
