Timing/ Boost table??? HPtuners??
Old Jul 8, 2006 | 07:42 PM
pwrtrip75's Avatar
Default Timing/ Boost table??? HPtuners??
using 2 bar SD HP Tuners.
Ok, my timing table only reads Cyl air mass up to 1.20 so when I log timing w/ 5psi of boost it reads in the same spot where I log 15psi. WTF??
How can I safely tune my car to run on 15psi and also run on 5psi? Wouldnt you think the 2 bar upgrade would make the timing table read higher also?
What is everyone doing? Or am I overlooking something?
...And now its raining out
Old Jul 8, 2006 | 09:39 PM
foff667's Avatar
LS1TECH Sponsor
http://www.hptuners.com/forum/showthread.php?t=6692
Old Jul 9, 2006 | 12:43 PM
pwrtrip75's Avatar
heres what is said;
"at this time the answer is no. As a workaround you could modify the injector flow rates and VE table to give lower g/cyl values."
I dont understand this and how it would work and how the injector flow rates or VE table would effect the spark table? Can anyone explain?
Old Jul 9, 2006 | 03:12 PM
kbracing96's Avatar
I guess that why EFILive added this table to its custom OS. I am currently just using it as over boost protection.
I think HPTuners as something in the works that is similar, but we have had this for some time now.
Old Jul 9, 2006 | 04:05 PM
soundengineer's Avatar
basically the cylinder air is calculated....not an actual value as there is no physical sensor for this in our less than $7,000,000 cars..LOL
so if you up the IFR table and VE #'s decrease then your calculation also decreases as the math invilves the VE table values...
juts try increasing your IFR and decreasing your VE by a simal percenatge and you will see that it will also decrease your "calculated" cylinder air...
simple math..nothing more.....
