Tuning for fuel mileage ?s.
Old Jul 10, 2006 | 10:08 PM
Stampede4ever's Avatar
Default Tuning for fuel mileage ?s.
Looking for some general info. how to tune for fuel mileage, what to do, what to look for, ect. I thinking of putting a restrictor plate on, reducing the incoming air, which would require less fuel. Is this possible?
Thanks.
Old Jul 10, 2006 | 11:04 PM
Billf6531's Avatar
... and what is it you drive?
Old Jul 11, 2006 | 04:41 PM
Thinking of putting a D.O.D engine in a Fox body Mustang.
Thanks.
Old Jul 11, 2006 | 05:13 PM
slow's Avatar
restrictor plate will increase vacuum.
Vacuum is BAD for fuel economy, as you have pumping losses.
Things that help fuel economy.
Timing, locked torque converter, and EGR are just a few.
Ryan
Old Jul 11, 2006 | 09:06 PM
98camaroLS1M6's Avatar
Ryan
What kind of timing, lower or higher?
Old Jul 13, 2006 | 08:31 AM
muncie21's Avatar
Lower the O2 switch points for your cruising airflow/rpm.
Old Jul 13, 2006 | 09:55 AM
SSpdDmon's Avatar
1. Go to Home Depot.
2. Purchase 2x4x4 block of wood.
3. Return to car and place block of wood behind gas pedal.
Congratulations! You should now see a 5~50% increase in gas mileage.
Hmmm...I should do one of those 2am infomercials and sell blocks of wood for $19.95 + $5.95 shipping and handling.
Old Jul 13, 2006 | 11:46 AM
SMOKINV8's Avatar
I read Jimmy's thread on the HPT forum about that a while back... how do you determine which airflow mode corresponds to which driving condition?
Old Jul 13, 2006 | 11:58 AM
BanditTA's Avatar
I'd tweak TC lockup first
Old Jul 13, 2006 | 01:06 PM
Zick's Avatar
Old Jul 13, 2006 | 01:32 PM
muncie21's Avatar
Go for a drive and log dynamic air in g/sec. Figure out what that is during steady state cruise. Once you have the g/sec range (for example: 28-44 g/sec) that you run in during cruising adjust your O2 switch point accordingly.
There are only 9 airflow modes that can be selected in the rich/lean airflow mode table. I selected 2 modes to be my lean cruising settings and dropped the switchpoints in those areas to 3xx mv.
