Desired IAC position vs. IAC motor position
Originally Posted by V6 Bird
SOunds like you need to find you a new dealer...and a new tech to work on your car and diagnose it. sounds to me you are stuck back in the Shaner days..hahah
In all seriousness Rich, (beenfetchedlately here BTW
] have you ohmed the wires to check them for resistance? Shoot me some PMs with the specs on the car...i cant remember if Shaun did a cam in that car a while back or not. Been too long ago since ive seen you of the car...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Injectors clogged normally wouldnt cause a misfire like your seeing. Ive seen cars surge though because of that and plugs being doused (sp) with fuel and then it misfires because its basically fouled then and only hits every other cycle or so.
If you need someone to get down in there and lend a hand...I can help its just that im not all that close to ya...
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Swap the coil packs first. Then test the ohms on each of the wires. The injectors are quite easy as well and would take about 30 minutes to move to another location...
Yes, I'll swap the coil packs, wires and see what happens. I also think I'll swap back in the original TB after that job, just to make sure it really was causing the surge.
Originally Posted by P Mack
Are you sure your pcm even know's the throttle's closed? I thought the tps voltage had to be below 0.4 V or so for the pcm to apply the idle corrections.
It's to bad you can't log stit's or you could see for sure if they're updating.
What fuel trim cell are you in at idle?
What is your TPS percentage?
There are two catastrophic conditions that keep popping into my mind: the PCM's at fault, or my eight year old torque converter, who's life started out as a 2800 stall then re-stalled to 3000, and is causing the idle surge is in need of some freshening up. Keep in mind the surge was most noticeable when shifted into gear.
I guess you're all suspecting now that I have no life outside of this forum, huh?
Let me edit this a little... When I mention my TC, I say that because I still notice some minor surging when I shift back into park (more than what I'd consider normal), but no where near the amount it had with the other TB in place...
I sure would like a Fuel Trims 101 course. I'm sure it's been discussed here thoroughly, but you tend to get opinions and disagreements mixed in which causes the subject to become convoluted, which in turn causes me to become disinterested.
How 'bout: What does Fuel Trim 20 indicate or provide to the engine? What about Fuel Trim 4?
I simply wanted you to check resistance in the wires because i wanted to make sure they were all within the reasonable amount of resistance to rule out a plug wire. Ive never had issues with the heat shields not being there on the head side of the wire Rich, but thats not to say that you cant install them. They are a direct swap you know?
The V6 Bird part is all part of a secret society of street racing stuff i was in for a while....My car was just like yours except sleeper and stock like...
BTW, your garage and mine, run about the same temps..I do side work sometimes on the weekend and work in it often...
Interesting. I gather this is an HPT window? Two questions: What is the formula to convert *in Hg* to *kPa*? Atap expresses MAP as the former. Also, what is that percentage number I see next to the Trim number?
What pisses me off is the fact that, for the money I just spent at the dealer (potentially needlessly) I could own the HP Tuners tool right now!
Mr. Savings Account would disagree! But, since you need to upgrade from your old version of LS1 Edit, let's split the cost of a multi-VIN license, if that rule applies. Whattaya say ace?
Mr. Savings Account would disagree! But, since you need to upgrade from your old version of LS1 Edit, let's split the cost of a multi-VIN license, if that rule applies. Whattaya say ace? ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Im not in the position to purchase anything right now except Big Stuff 3.
Just wanted to note that the idle surge issue and my questions concerning the IAC have been resolved by replacing the TB. Looks like it was either the TB or, but not likely, the IAC valve. At this time I have no driveability issues, including no noticeable "misfires" as was reported by ATap previously (I would think that I would notice 22 on one cylinder during one count cycle at idle). I swapped coil pack and wire #7 & #5 last weekend; the misfires still showed as coming from #7, so I think I can rule those two elements out. Fresh AC plugs were installed during the new TB install as well. What I find interesting (or maybe I just don't understand what constitutes a misfire) is that, after a WOT run, powering off the motor and then restarting after a bit of cooling, one cylinder was definately not working for a short period. ATap reported NOTHING during this event.
BTW, the tech at the dealer reconnected the TB coolant lines but forgot to reconnect the vacuum line after he replaced the TB.
(Yes, I did notice a slightly smoother idle and pickup during acceleration after I reconnected it.)
I think I need to start an HP Tuners or EFI Live savings fund.
-OR-
V6 Bird, what is Big Stuff 3, would it be beneficial for my car, and, we learned SHARING when I was growing up.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Thanks again to all for your input. -Rich
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
-OR-
