Vacuum modulated tranny - disable pressure control circuit codes?
High on diesel fumes
I have a vacuum modulated 4L80E, and my PCM is throwing a Pressure Control Circuit code. Anything wrong with just disabling the code in the tune?
Originally Posted by wait4me
You can do that.
The computer dont have the ablity to change pressure any more.
No prob. It kinda sucks that they put in the vacuume mod because then we dont have complete control of the trans pressures, but it makes it easier on the trans builders when the tunes are not set up correctly and kill the clutches prematurely.
That's what my guy was worried about - I asked him to put the EPC back in, but he said he has seen problems with tunes getting changed inadvertently and breaking parts. Sucks for me cause to get my manual 1st and 2nd to work correctly for towing I have to have a Gear Command valve body, so I'll be full manual except for OD. Shift points are screwy too, the tranny doesn't shift exactly when the PCM tells it to at WOT so I had to manipulate the shift tables to compensate (like telling it to shift at 40 mph/5900 RPM to get it to shift at 60 mph/6300 RPM from 1-2). Also, since I am FI I get full pressure shifts at about 40-50% throttle.
