Can I temporarily "tune out" the IAT sensor ??
you want to keep the IAT sensor... what I would do (and what others have done) is run a straight tube from TB to lid , then drill a whole in it and place the IAT sensor in it
However... if you absolutely want to disable it... just do the resistor mod ... i forget the sizes.. but you can use a resistor to trick the IAC into thinking it's a constant temperature
But I don't HAVE that IAT sensor yet....it'll be here in 2-3 days and I'd like to run it this way until then.....
You can pull the iat sensor out of the maf with a pair of needle nose pliers. Then just take the sensor and put it in your intake tube. I used JB weld on mine. Then you just have to cut the wires and wire them to the sensor.
This is assuming we have the same maf.
Originally Posted by Yelo
What value to get ~110º temps ?? (I'm trying to be somewhat realistic with my IAT temps)
See sticky
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
towards the bottom "IAT vs Resistor vs Reported Temp" should get you what you want
See sticky ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
https://ls1tech.com/forums/showthread.php?t=287094
Would you happen to have another link?
"IAT vs Resistor vs Reported Temperature" is unavailable.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
