CASE relearn...when?
Old Jul 23, 2006 | 08:23 PM
ninobrn99's Avatar
Default CASE relearn...when?
When would you want to do a case relearn? Is it absolutely necessary on a new motor install? Im just trying to get an idea of when everyone does it and what you look for before you do it.
Old Jul 23, 2006 | 08:35 PM
TAQuickness's Avatar
any time the relationship to the crank, crank angle sensor, and/or the PCM changes. i.e., new crank, new pcm. Not a bad idea after a cam swap, or a full flash either.
Old Jul 23, 2006 | 08:38 PM
ninobrn99's Avatar
so does a new motor install always need one or only if it causes problems?
Old Jul 23, 2006 | 09:02 PM
yes. when a new motor is introduced, regardles if the crank was reused, the relationship between the crank reluctor and crank angle sensor has changed. if a new crank is used, you have a new reluctor, change in crank angle sesor relation, and the relation of both to the PCM has changed.
The crank reluctor is a map of the crank position. every reluctor is subject to machining tolorances. Anything that disturbs reading the map, or when a new map is used, CASE relearn should be performed.
