BS3 : Car runs horrible when its cold
I can fix it by tweaking the fuel table around as it warms up but thats obviously not the correct solution.
Any suggestions?
Kurt
Kurt
I wonder if I can put a -% in there because it was almost exactly 50% less fuel when it was cold. Guess I'll give it a try a little later!
Kurt
for high MAP, low temperature and compounds any
accuracy problems you might have with the VE table
values at low RPM and big cam (which usually push
in the same direction). This drives your idle MAP even
higher as the motor is choking on fuel, and enriches
even more. This is direct, running mixture (not just
close-in after-start).
