High idle when coming to a stop?
You could do either of the following for a start:
1. Lower your Idle Air RAF table by 5%.
or
2. Lower your Throttle Follower Airflow Tables; Decay, Delay, and Decay in gear. Make your decrease in the mph or in the particular gear(s) where you experience the problem. Start with a decrease of 10%.
A search would have yielded all of the above and can give you some more insight into the various other idle tuning tables
Do you have the capability to tune it yourself? If so, look at running airflow, idle RPM, VE at idle and the throttle cracker/follower. Your answer lies in these small number of parameters.
