Traction Control
Old Aug 7, 2006 | 12:02 PM
v-8's Avatar
v-8
Default Traction Control
I was looking around in my car, under the center console, i noticed that my car is wired up for traction control, but there is no switch. my ABS INOP light and brake light are on, is there a connection?
Old Aug 7, 2006 | 12:19 PM
2001NBMZ28's Avatar
Something else is going on. My car didn't come with ASR, no switch - but has the wires there behind the panel.
Old Aug 7, 2006 | 12:22 PM
v-8's Avatar
v-8
ok, i thought of getting a asr swich and just trying it, i need to check on the build sheet to see if it came equipt, i dont think it did tho...
Old Aug 7, 2006 | 12:26 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Do a search. There is a thread about the wiring harness that GM used. Something about it was cheaper to mass produce one wiring harness instead of making two different ones
Old Aug 7, 2006 | 12:30 PM
2001NBMZ28's Avatar
ASR/TCS cars have RPO code NW9, and have 4 channel ABS vs. 3 channel.
Old Aug 8, 2006 | 07:29 AM
RZRSEDGE's Avatar
Also you could look on the firewall by the batery and see if your throttle cable runs to a cylinder shaped motor then to the throttle body. If it does then it had traction control, if the cable just runs straight to the throttle body then it did not. Someone could have taken it off; but I think that would be alot of work.
