long tubes, slow response throwing a code?
what if: put the o2s closer to the cyl (one cyl that is)? to speed up reaction
camaro ´98 M6 no tune whatsoever, never hooked to a handheld.
the headers don't affect it that much.... several people say that getting LT headers causes the 02s to go bad quicker... which may be true, but i don't think so.
in a few days I will receive my HP tuner suite, Ill have more detailed info then.
I dont remember the code number but it was related to low or none activity, The tech said that if you did not used the sens for a long time (almost two years) they may have gotten south :-( this is because of humidity.
the injectors are OEM ´98 stuff (high flower ones), new airbox, ported maf, polished TB, CNC stage II heads, lunati cam, TL headers, free flow ext, ls6 block, ls6 pistons teflon coated) new tight main bearings , new rod brgs, blueprinted everything, lightened fwl; and so on.
definetelly in need of a tune!
