fuel relay problem
Old Aug 8, 2006 | 07:41 PM
88s10's Avatar
Default fuel relay problem
Ready to start but have fuel pump issues. The wiring harness is a 98 I am using efi live. Wire thirty seven on the blue terminal from pcm is always 12v with a multi meter but it wont light a test light and I cant turn off power with the bidirectional controls. Any thoughts ? Im wondering if it’s a computer problem ? I did the harness my self and every thing else is good to go. If I cant find the problem con I wire the relay off the ignition? Somebody out their has got to know. I already posted this in conversions and hybrids. Im thinking it was the wrong place
Old Aug 9, 2006 | 03:05 AM
joecar's Avatar
Wire 37 feeds the fuel pump relay;
Check wire 37 for short to power between the relay and the PCM; if there is no short, then the PCM may be faulty;
if there is a short, find it (also check for bent pins at the PCM connector) and fix it.
Old Aug 9, 2006 | 12:19 PM
88s10's Avatar
thanks joecar Im using a bench harness thier is no short it must be a foulty pcm
