ls1 edit
Old Aug 11, 2006 | 06:27 PM
DSRCAM's Avatar
Default ls1 edit
where can i buy ls1 edit for my laptop??
Old Aug 11, 2006 | 06:44 PM
Blacker's Avatar
You can get it from Carputing but, why???? LS1 Edit is no longer a competitor in the LS1 Tuning World. Look at HP Tuners or EFI Live as they are complete tuning suites.
Old Sep 14, 2006 | 09:24 AM
Hersker Hans's Avatar
Im considering LS1edit since ive got two LS1 engines, and i could buy it and a cheap license for the second engine, and remov vats o2, and maybe tune for a turbo on one of the engines at some point. Why is LS1 edit so bad? and what are the limites compared to the other? please dont paste the sticky, lets discuss this, ive been trying to find a good thread on ls1edit.
Old Sep 14, 2006 | 09:35 AM
98SS2836's Avatar
you buy efi live you already get two licences and unlimited tuning for 98's I have both ls1 edit and efi live ls1 edit will do everything you want but you'll have do a **** load more work. EFI live can do a lot more than edit. Custom operating systems is one of the benefits of efi live. All I say is do research research research and more research or you'll spend a lot of money and time.
hear is a start. http://forum.efilive.com/index.php
Old Sep 14, 2006 | 09:55 AM
foff667's Avatar
LS1TECH Sponsor
hptuners offers up to 4 pcm locked licenses with your initial $499 purchase, a powerful scan tool that is able to scan nearly any 96+ GM vehicle and will soon offer scanning of Ford/dodge at no extra charge. Custom Operating systems & Real Time Tuning is only two clicks away as well which makes tuning fun not to mention much easier and less time consuming. Vin locked licenses with HPTuners start at only $99 with no shipping/handling charges since its all done via an emailed application key. Upgrade to the MPVI pro & that adds standalone data logging of over an hour for all supported PCM's as well as 4 analog inputs & 2 outputs and you'll be well on your way.
www.hptuners.com
Old Sep 14, 2006 | 09:57 AM
Billiumss's Avatar
Exclamation
LS1 Edit what?
Go with HP Tuners or EFI Live, MUCH better over LS1 Edit.
Old Sep 14, 2006 | 11:04 AM
Magnus's Avatar
LS1TECH Sponsor
HP Tuners gives you more licenses for more vehicles at more affordable prices.
Old Sep 14, 2006 | 02:37 PM
thank you so much!, i consider efilive or hpt then. ive got one 2004 gto ls1 engine, and one 98 ls1, both t56, the 98 im leaving stock, maybe just adjust fan start, rpm limiter and remove vats and o2.
Old Oct 11, 2006 | 03:40 AM
ok, just ordered hptuners, where do i get the obd-II plug for my car, i havent got it since its a swap.
Old Oct 11, 2006 | 06:25 AM
foff667's Avatar
LS1TECH Sponsor
http://www.eficonnection.com/
not sure if casperselectronics sells them
