Errors out the ass hole with autotap
Old Aug 11, 2006 | 07:46 PM
Phlip00WS6's Avatar
Default Errors out the *** hole with autotap
I'm using the AT1 cable and version 2.05 software. I took the box apart and it says AT1 version 1.05. Its the serial version and I'm using the $40 dynex serial to usb converter from best buy. I'm gettin a overflow error when I try and log a run, and everytime I try to view my front o2's it disconnects from the pcm, and if the car is idling it will keep disconnecting until I start driving around then its not a problem. Is there any other software that works with the AT1 interface? Or any way to fix all this?
Old Aug 11, 2006 | 08:20 PM
TAQuickness's Avatar
I believe EFILive works with that cable. Might want to send an email to support at efilive dot com
Old Aug 11, 2006 | 10:37 PM
Phlip00WS6's Avatar
Damn that would be nice, just to have the EFIlive scanner. I downloaded it and it doesnt seem to work with the interface or maybe somthing else is wrong..
Old Aug 12, 2006 | 04:35 AM
it's licensed to the cable. send an email to support at efilive dot com
Old Aug 12, 2006 | 04:38 AM
Phlip00WS6's Avatar
I sent an email and recieved a license key and got all that taken care of, so now its registered.. but its still saying ERR_NOCABLE/31
Old Aug 12, 2006 | 05:03 AM
Phlip00WS6's Avatar
Oh yea, I was checkin a few of your link in your sig and I went ahead and ordered the Oil bypass kit.. you dont want all that expensive oil to go through your engine.
Old Aug 12, 2006 | 06:04 AM
When you open the scan tool, click edit -> properties. Under the connection tab, select the cable you intend to use.
Old Aug 12, 2006 | 06:05 AM
you also may want to sign up on the www.forum.efilive.com.
Old Aug 12, 2006 | 06:06 AM
Phlip00WS6's Avatar
I tried that.. I was reading through the user manual for efilive scan tool and it says
Cable type Support
AutoTap AT1 V1.x Standard, Scan only
The V7 Scan Tool does not support this interface
If I cant use the V7 is there anyway I can download the V6?
Old Aug 12, 2006 | 06:18 AM
Not sure if V6 is readily available for download. Might try sending another email to Live and ask them where you can get it. I'm sure they will be able to take care of you
Old Aug 12, 2006 | 06:22 AM
If you can swing it, you might consider getting the V7 scan tool and the Flashscan interface (~$250 IIRC). V7 has a lot of nice enhancements over V6, not to mention the FS cable is light years ahead of the ATAP cable (read external inputs).
Old Aug 12, 2006 | 11:23 AM
Hugger's Avatar
Phlip,
If you don't mind me asking, how much did it cost to get everything you needed to make your ATAP cable work with EFI Live? My cable is a version 1.01 and I am interested in swapping over to EFIlive. You can PM if you would prefer not to post the info.
Old Aug 12, 2006 | 06:53 PM
Phlip00WS6's Avatar
youll need version 6.0 software, and i got it for free :;
Old Aug 19, 2006 | 10:11 AM
emarkay's Avatar
I remember a few issues with USB/Serial and VV. I know that the "Edgeport" brand adapter was recommended, but I recall that was for serial to USB.
Have you contacted B&B on this - the makers of Autotap?
Remember the Autotap V1 adaptors do not do Bidirectional communications.
