after using fuel trims to dial in VE table in CL SD..
Old Aug 15, 2006 | 10:44 PM
ZL1Killa's Avatar
Default after using fuel trims to dial in VE table in CL SD..
now, when i plug back in my MAF and enable it; are the fuel trims going to go crazy again? should i leave my MAF table alone, since i dialed in my VE or adjust the MAF by a certain percentage based on the fuel trims being + or -?
Old Aug 15, 2006 | 11:17 PM
Robert56's Avatar
This might help, it worked for me.
https://ls1tech.com/forums/pcm-diagnostics-tuning/557918-ltft-troubles-injectors-42-s.html
Robert
Old Aug 16, 2006 | 09:26 AM
ZL1Killa's Avatar
preciate it man, I see you just learned a lot of that. I just did it for my old setup and it had been so long i almost forgot how to do it. LOL.
Old Aug 16, 2006 | 09:31 AM
ninobrn99's Avatar
histograms are you not using a WB? man its day and night difference with one! I just started using mine and **** is on point. My ve's are -4 to 0 for the most part, but were way off from using the trims!
Old Aug 16, 2006 | 05:01 PM
ZL1Killa's Avatar
i got a wideband also.. i use it mainly as a check , if you know how to do it and do it right using the trims is within a good 2% of that wideband
Old Aug 16, 2006 | 08:54 PM
Robert56's Avatar
Yea I had done it the old way with the spread sheets, but this is much better, easier and much more correct. I use my WB for my PE curve, yes curve.
Robert
