Release DTCs without scanner?
Old Aug 17, 2006 | 11:03 PM
OldSchoolFormula's Avatar
Default Release DTCs without scanner?
Is there a way to release codes without a scanner? The car isn't drivable at the moment and Im getting a check engine light. Thanks.
Old Aug 18, 2006 | 11:50 AM
2001NBMZ28's Avatar
What year is your car? I'm thinking '93 was the last year you could do it without a scanner.
Old Aug 18, 2006 | 01:49 PM
It's an '01 drivetrain/ECU. I know you can get the codes out of OBD2 Chryslers by turning the key on and off several times, and cant you jump a pin or two on OBD1 cars after 93?
Old Aug 18, 2006 | 01:54 PM
foff667's Avatar
LS1TECH Sponsor
not that im aware of, but I will say most autozones will scan your vehicle for free.
Old Aug 18, 2006 | 02:04 PM
ChrisS@sdpc's Avatar
This is one cool feature on the C5's. You can scan through all DTC's on the DIC and reset them by holding a couple of buttons on the dash.
Old Aug 18, 2006 | 02:39 PM
Xtnct00WS6's Avatar
They'll even clear the code for you too if you want.
