couple of after cam swap ?
Old Aug 20, 2006 | 10:43 AM
nvrstsfd23's Avatar
Default couple of after cam swap ?
i am having trouble with my car after doing a cam swap with tuning. at random times my tsc will turn off and the switch wont work but then all of the sudden it goes back to normal and works fine. also if the ac is running and i start the car it wants to stall on me.
Old Aug 25, 2006 | 12:02 AM
nvrstsfd23's Avatar
can anybody help me on this
Old Aug 27, 2006 | 03:12 PM
Killer_Bluebird's Avatar
Thats is a similar cam to what I have waiting to be installed next weekend in my car. I got the TSP 231/237 .598/.595 mine is a 114 LSA though. I just got HPT so I can't really help. I will be getting my car tuned at GMR once I finish the install. Are your numbers in your sig before or after your cam? Hopefully they are before. Let me know how it goes may be we can compare notes after my cam is installed and tuned.
Old Aug 27, 2006 | 03:42 PM
SPEEDYws6's Avatar
is p0121 or p0106 set?
Old Aug 28, 2006 | 04:48 PM
BIRDONNOS's Avatar
if so and you have hptuners goto edit/engine diagnostics/general then set your P0121 Error max map to (100) then set your P0121 Error min map to (0)
i just installed a cam similar to the t-rex and it was pulling 71kpa at idle throwing this code causing my TCS to shut off also. hope this helps out as i just went thru this myself.
Old Sep 1, 2006 | 10:02 AM
nvrstsfd23's Avatar
yeah ill check it out and the numbers in my sig are after the cam swap at the wheels which is pretty good if you ask me.
Old Sep 13, 2006 | 06:00 PM
00blownWS6's Avatar
anyone know if the p0121 settings will cause misfires and cause a manual 6 to hesitate at light throttle
Old Oct 6, 2006 | 12:40 PM
camarochvy21's Avatar
I just did another cam swap but this time I put the MS3 in. I got the p0121 code and just push on the throttle sensor and it work great. After driving about half a mile, the ses light went out. But before that, my car was running like ****!
Old Oct 13, 2006 | 11:18 AM
dixonk's Avatar
Having the same problems and I even set the tables to 100 max and 0 min and still misfiring and running like crap. Let me know what you figure out so I can fix mine.
