Wont Start After Engine Install
Old Aug 25, 2006 | 04:33 AM
joecar's Avatar
You said you get fuel and spark, so the problem might be VATS related.
Old Aug 26, 2006 | 04:32 AM
TWISTEDTA's Avatar
I hope so man, I called my local tuner to come down when he gets a chance... we'll see if he can figure it out
Old Sep 11, 2006 | 12:43 AM
pewter 01 SS's Avatar
did you ever figure this out??.. im in the same boat basically. i did basically everything you did already except the crank sensor which is next.
Old Sep 11, 2006 | 05:06 PM
TWISTEDTA's Avatar
Just PMed you back man
& just for everyone else that tried to help me out, the answer is negative. Still hasnt started but my tuner says the timeing sounds like its very off. The cam was installed dot dot so im thinking it might be my cam sencor.... still doesnt explain why it doesnt pop a code but i guess time will tell...
Old Sep 11, 2006 | 05:11 PM
pm'ed you back might be the reluctor ring if it isnt the cam or crank sensor..
Old Sep 12, 2006 | 01:13 AM
macknmikey's Avatar
it should still start if the cam sensor is bad it will just take longer than usual
