Egr
Old Sep 12, 2006 | 08:48 PM
Traitor LS1's Avatar
Default Egr
I have an LS6 intake on a 2000 camaro Z28 it came with it on and the owner before me tapped the EGR back into I want to get rid of it and plug the hole and block it off the exhaust manifold as well just get rid of all of the egr stuff and I was wondering is my car gonna run shitty if I try to drive it afterwards I know a code with show but do I risk any motor damage or any damage at all
Old Sep 13, 2006 | 04:14 AM
TAQuickness's Avatar
if anything, the car should run better
Old Sep 13, 2006 | 09:01 AM
kenkaru's Avatar
As long as you plug the holes, you won't notice a difference.
Old Sep 13, 2006 | 07:39 PM
2001WS6Vert's Avatar
An E.G.R. sytem will reduce detonation when active. So you need to make sure you don't hear (or log) any detonation under load (especially up hills). If the car is detonating you may have to adjust the timing table down a little.
Old Sep 14, 2006 | 01:34 AM
Josh McGrath's Avatar
made ZERO difference on mine. ZERO grrrrrr I even put it back on after hearing that to see if it helped my low rpm ping
