intermittent P0332 question
Old Sep 16, 2006 | 10:00 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Default intermittent P0332 question
I recently began getting an occasional p0332 knock sensor bank 2 low input code. Just today, it seems to have become constant. When the code pops, the scanner shows a constant 2.9* knock retard. I'm just curious if this is most likely a wire problem or an actual sensor problem. I was fairly careful with the FAST install, but I guess I could have damaged something. However, I installed the intake months ago, and this problem just recently surfaced.
Old Sep 16, 2006 | 11:14 PM
ZL1Killa's Avatar
what year is the car?
also when you installed the intake there could have already been a leak under the intake where water got into the knock sensor wholes. might want to check that.
how often does it happen
Old Sep 16, 2006 | 11:27 PM
gametech's Avatar
It's on the '04 gto. There was no leak before or after the intake install. When it first started, it showed the error maybe every third or fourth time I drove the car. Now it is continuous. The ses light has only came on twice because of this. The other times I noticed it because I monitor KR on the scangauges. I'm just wondering if I should go ahead and buy another knock sensor before I pull the intake off, or if it is probably wiring.
