wont fire!
Old Sep 16, 2006 | 11:21 PM
BoostedWS7's Avatar
Default wont fire!
new engine... i tuned for injectors only to fire up. thats all i need right?
just turns,.... no hint of even tryin to fire.
blower motor, blower cam, took off a.i.r. system. the blower is off. the bitch should atleat try to start, rigfht? harness is hooked up correctly.
please help!
im thinkin at this point it could be cam or crank sensor related... how do i check? and what the hell do i do? i have fuel.
ahhhh
Old Sep 16, 2006 | 11:46 PM
HumpinSS's Avatar
do you have spark. have you pulled a wire and tried to see if it arcs over to a ground
Old Sep 17, 2006 | 11:45 AM
BoostedWS7's Avatar
no spark...shiiiit
Old Sep 17, 2006 | 02:41 PM
BoostedWS7's Avatar
im guessin its a cam or crank sensor issue. or harness problem...
anyone expeience sensor problems? frustrated
Old Sep 18, 2006 | 04:04 PM
BoostedWS7's Avatar
anyone?
Old Sep 21, 2006 | 01:03 PM
Jed Z06's Avatar
Originally Posted by BoostedWS7
anyone?
Same thing happening to me.
Found the crank position sensor not connected.
Is right behind the starter
Old Sep 21, 2006 | 03:42 PM
RedWS6 00's Avatar
That would do it, no crank position sensor, the PCM dont know when to fire so it dosn't fire. The crank position sensor is the culprut on other vehicles too, not just the LS1.
Old Sep 21, 2006 | 03:48 PM
v-8's Avatar
v-8
Mabe check the ECM fuses???
Old Sep 24, 2006 | 05:59 PM
BoostedWS7's Avatar
car has been sittin, havent had time to mess with. but i know the plug isnt unplugged, i checked that first. another question. does the cam sensor have anything to do with ignition or does it only control fuel timing?
i know this has to be something stupid. i hope. ha.
Old Sep 26, 2006 | 06:48 PM
BoostedWS7's Avatar
k, changed the crank sensor from another engine i know works. still no spark. do i really have to take off the intake and change the cam sensor? does it even control spark timing? all fuses are good, using the same pcm and harness as before when it was stock. WTF
Old Sep 26, 2006 | 07:12 PM
Lafngas98Z's Avatar
I am going thru the same problem, car turns over but no fire. I have been researching the heck out of this. FYI The car will start and run with out the cam sensor functioning properly.
Old Sep 26, 2006 | 07:34 PM
BoostedWS7's Avatar
yea, this is bullshit. ha
Old Sep 26, 2006 | 08:58 PM
BoostedWS7's Avatar
somebodyys gotta know.... c'mon ! uuugh
